engine idle with AC on
Old Jun 22, 2013 | 12:25 PM
cudadriver's Avatar
Default engine idle with AC on
with AC on (works great by the way), at idle and in gear the engine sounds and feels like its missing. AC off engine runs great. checked the codes and got P301. is there any way to tell if the P301 is caused by the AC or if its real cause is someplace else. Thanks
Old Jun 22, 2013 | 04:56 PM
when u turn on the ac is the fan coming on?
Old Jun 22, 2013 | 11:12 PM
cudadriver's Avatar
Yes, everything seems to be working. fan runs as required with in regular AC mode and runs constant when in recirculate mode.
Old Jun 23, 2013 | 01:48 AM
Im talking about the fan under the hood not the one inside
Old Jun 23, 2013 | 07:29 AM
cudadriver's Avatar
Yep so am I.
Old Jun 23, 2013 | 01:49 PM
cudadriver's Avatar
Got an update, AC apparently has nothing to do with it other than the fact that it "loads" the engine. I got a chance today to put the car under heavy acceleration and the engine light came on flashing. Soon as I backed off the throttle, the light went out. Checked the "P" codes again and still only got P301, misfire on cylinder 1. What can cause this? Thanks
Old Jun 24, 2013 | 12:43 AM
plugs wires coil pack
Old Aug 1, 2013 | 12:26 AM
cirrus98's Avatar
Might I even suggest a clogged fuel injector. Happened on my Cirrus. Cylinder 2 Misfire and that was the problem.
Old Sep 4, 2013 | 12:31 PM
Breaking300's Avatar
Here's some explanation about that code
Code P301 cylinder 1 misfiring. : OBD-Codes.com
70 roadrunner
Dec 3, 2014 07:48 AM
sonyatracie
Mar 10, 2011 02:12 PM
Andy_123
Nov 19, 2010 10:47 PM
kbosse
Jun 17, 2009 09:18 AM
macfarlane300
Feb 2, 2009 09:00 AM
