Newbie - wierd double trouble codes
Old May 7, 2020 | 08:20 PM
jimkari1's Avatar
Default Newbie - wierd double trouble codes
I recently purchased a 2005 PT Cruiser Limited (125K miles). It needed some general maintenance and a few repairs so I replaced the timing belt and water pump. I also replaced the turbo center section, the radiator, and the lower left front control arm. The engine runs well, but I am receiving weird trouble codes. They are coming in pairs of two. Here is what I'd received so far.
P0108 (MAP pressure circuit high) & P0123 (Throttle Position Sensor Circuit High)
I thought these may have been related to the repairs and the fact that I cranked the engine over to check compression when the intake and ignition was off the car. I was able to clear those by disconnecting the cam position sensor, running a PCM scan, clearing the codes, and then 108 and 123 did not come back. (I read this on the forum),
But then I received:
P0128 (Coolant Temp below normal) and P0440 (EVAP system), I thought 128 might have been due to the engine being a little low on coolant because of the water pump / radiator replacement and I noticed two wires going to the EVAP system were a little frayed. I added coolant and taped the wires, cleared the codes and they did not come back.
But then the next time I started the engine I received the following two codes:
P0031 (O2 heater control circuit low bank 1 sensor 1) and P0037 (O2 heater control circuit low bank 1 sensor 1)
I'm thinking my problem is probably not these individual issues, but possibly something with a ground or the PCM.
I really appreciate any advice. I am really stumped and it is getting frustrating. Every time I think I have this car fixed, something else pops up.
Thanks,
Jim
dale_hopkinson
13
Oct 28, 2014 02:31 PM
pauley
Aug 16, 2014 01:00 AM
bdevil
Dec 8, 2012 05:29 PM
master tech
Apr 6, 2012 07:16 PM
mayNArd3k
Jan 20, 2012 03:47 PM
