Couple of trouble codes
Old Sep 29, 2012 | 04:58 AM
bdevil's Avatar
Default Couple of trouble codes
My wife's check engine light just came on and after hooking up the code reader, I got codes P0171 (system to lean) and P0521 (Engine Oil Pressure Sensor/Switch Range/Performance).
Not sure if they are some how related or it was just a coincidence.
Has anyone had these codes pop up and what were the culprits?
Thanks,
Sal
Old Sep 29, 2012 | 02:29 PM
15951a\'s Avatar
P0171 can be caused by:
- Restricted fuel supply line
- Fuel pump inlet strainer plugged
- Fuel pump module
- O2 signal circuit
- O2 return circuit
- O2 sensor heater operation
- O2 sensor
- MAP sensor operation
- ECT sensor operation
- Engine mechanical
- Fuel filter/pressure regulator
- PCM (Powertrain control module)
P0521 can be caused by:
- Engine oil/engine mechanical
- Excessive resistance in the (G6) engine oil pressure sensor signal circuit
- Excessive resistance in the (F855) 5-volt supply circuit
- Excessive resistance in the (K900) sensor ground circuit
- Engine oil pressure sensor
- PCM
The only obvious common link between the two codes is the PCM -- I hope that's not the problem.
Old Dec 8, 2012 | 05:29 PM
bdevil's Avatar
Update...
I removed and and cleaned the MAF sensor which was dirty and a few days later the check engine light cleared and has not came back on again, it has been about two months now.
I also did an oil/filter change that same day so I am not sure which of the two or if both actually contributed to the clearing of the check engine light.
One more thing, I have not hooked up a code reader to see if the codes are still there.
Jfizzle
Feb 22, 2020 04:37 PM
scottshaw
Aug 23, 2011 04:52 PM
Qckslvr
Jan 22, 2011 06:11 PM
valkyr
Sep 19, 2009 10:41 AM
bdevil
Sep 21, 2007 11:24 AM
