The turbo turd
Old May 31, 2025 | 08:53 PM
Theturboturd.vert's Avatar
Default The turbo turd
It's a 2005 pt cruiser 2.4l turbo. Having issues with idling, and running smooth. Replaced the battery with a brand new one started and ran good not perfect but ran kinda smooth, drove it and it did a lot better than expected. Slow to build boost but done good. Swapped out the spark plugs with new ones and it ran terrible, wouldn't idle, barely would start. Left it alone for a few days went to start it again and basically same results tho I did discover the serpentine belt slide off the pulleys, left it alone again for a few more days first turn of the key it didn't turn over, after pumping the gas as I was trying and it fired up and ran smooth again but wouldn't idle for long before it died, has over a half of a tank of new 93 Octane gas with injector cleaner. Any ideas????
Old May 31, 2025 | 10:24 PM
need codes in the computer along with Fuel adaptive data to start with
Old May 31, 2025 | 10:30 PM
what exactly do you mean? Like I'm getting a scanner tomorrow so I can see what codes it has. Fuel adaptive data???
Old Jun 2, 2025 | 08:13 PM
start with the codes then we can go from there
Old Jun 3, 2025 | 09:33 AM
ggoose's Avatar
Were the OE Champion copper spark plugs used as replacements? The 2.4l, particularly the turbo, run best on the Champion RE16mc gapped at .040in. Iridiums, in particular, are know to not work well with the turbo.
It is recommended that the spark plugs wires be replaced every 60,000 miles, or every 2nd spark plug change.
Old Jun 3, 2025 | 09:50 AM
yeah I typically would replace plugs and wires but short on money and honestly wasn't expecting the cruiser to work out like it is. I do have codes I'll be posting shortly if I can't with this response but I have a live recording of it thru my scan tool which if I can post here I'll find out but basically both short term fuel and long term fuel trims both showed zero or blank while it was idling. which after some research found out that could be from the cats being either clogged or bad and the system either can't read or reading incorrectly.
Here are the codes its currently got
Old Jun 10, 2025 | 09:39 PM
well the o2 sensors when warmed up help control the fuel adaptive so having both of them in not good working order would be an issue.
If you end up replacing them use Denso or NGK only no bosch
Old Jun 13, 2025 | 11:05 AM
that's the plan is to eventually just do away with the cats all together and just weld a bung in for the o2 sensor into a piece of pipe. But does anyone know about the 2.4l turbo that's in the dodge neon srt4s? I have a theory thanks to some info I was reading. If anyone knows anything about that car and the engine let me know.
Old Jun 14, 2025 | 09:39 AM
ggoose's Avatar
The fact the vehicle ran poorly after the spark plugs were changed suggests to me the spark plugs are incorrect, the spark plug wires bad, or possibly a failing coil pack (not typical).
Circuit high indicates an open circuit (high resistance), e.g. broken wire or corroded connector
Circuit low indicates a possible short (low resistance), e.g. melted wire insulation exposing the copper core.
This suggests a wiring issue, possibly in the harness running to the O2 sensors. Look for rub-throughs or melted wires.
Remove and clean the ground points on the driver side strut tower. They may look good but are known to cause issues.
The P0700 tcm code is a generic transmission code to trigger the check engine lamp. There will be a more specific code(s) in the in the transmission module itself (P07xx).
Removing the cat will throw a cat inefficiency code and light the check engine lamp as there will not be a significant difference between the upstream and downstream O2 sensors. Note removing the cat is a violation of federal law.
Pumping the gas pedal does not increase the amount of gas (as it would for carburetors). Does spraying starting fluid or throttle body cleaner into the intake allow the engine to fire? This suggests an issue with fuel delivery (possible failing fuel pump). Might be necessary to check fuel pressure (loaner kits available from many auto parts stores).
No crank issue after a few days suggests a parasitic drain on the battery. If the vehicle has fog lamps, suggest pulling the fog lamp fuse, #8, in the cabin fuse box. The steering column multi-function switch has been know to fail in the fog lamp circuit and drain the battery.
Old Jun 23, 2025 | 08:10 PM
Well the plan isn't for the car to stay stock for long. After i can get it running and driving things on it will change performance, looks and it wont be stock. So pay day its getting a new set of spark plugs, plug wires, and coil pack new gaskets for the intake possibly a new o2 sensors. If none of that straightens the car out it will be receiving new hi-flow cat with some other exhaust work done. Basically I'm curious if after all this gets done will it be reliable. If not then I'm looking for a parts car which will be an 03-05 neon srt4. Use the engine and trans from that to get this thing to make some power and send it possibly go down a drag strip but first it's gotta run decently
