'01 T&C squeaking sound when I turn the wheel. Is that coming from the rack or the steering wheel?
Old Oct 25, 2007 | 10:52 AM
tk1780's Avatar
Default '01 T&C squeaking sound when I turn the wheel. Is that coming from the rack or the steering wheel?
Is there any place to lubricate the steering wheel?
I changed the resevoir and put in synthetic fluid.
Old Oct 25, 2007 | 11:00 AM
moe's Avatar
moe
Default RE: '01 T&C squeaking sound when I turn the wheel. Is that coming from the rack or the steering wheel?
is the noise coming from inside of the car.?if so you might get away with lubing the boot at the base of the steering column.need more info.moe
Old Oct 25, 2007 | 02:47 PM
tk1780's Avatar
It's hard to tell where it is coming from, in or out
Old Oct 25, 2007 | 04:17 PM
moe's Avatar
moe
i know they had issues with power steering lines under the car.and an issue with the power steering hose itself,but that was for a different noise that you discribe. maybe truck tech or chry tech might know of something. sorry moe i don't know
Old Oct 25, 2007 | 06:06 PM
truck tech's Avatar
Hello, sounds like a dry outer tie rod end, or lower balljoint. There is a easy way to check. Go to your local parts store and get a needle grease adpt. for your grease gun.Stick itinto thegrease boot and pump in some grease. turn it back and forth and the drive it and see if the noise is gone. Noises travalin vech. so its hard to say. Good luck. God Bless!!
Old Oct 26, 2007 | 08:17 AM
tk1780's Avatar
it sounds like gym shoes on a wet floor
Old Oct 26, 2007 | 08:32 AM
moe's Avatar
moe
sure your belt is not slipping?
Old Oct 26, 2007 | 11:34 PM
master tech's Avatar
You could have a dry boot at the lower steering coupler or a fan belt tensioner that is frozen or even ball joints or tie rod ends. Some how you need to isolate the sound/ noise.
Old Oct 27, 2007 | 04:21 AM
F150's Avatar
My 2001 T&C Limited does the same thing but it's only in the garage on the smooth concrete, Outside on a rougher surface it's quiet.
Old Oct 30, 2007 | 10:39 AM
tk1780's Avatar
Default It only happens when I turn the steering wheel, so
that is why I think it is the steering and not the belt or tensioner.
Could it come from the rack?
Aaron O'Boyle
Cirrus & Breeze
Oct 30, 2014 09:26 AM
Juventino Guerra
Apr 16, 2012 10:14 AM
Juventino Guerra
Apr 11, 2012 10:35 AM
janzen300
Feb 15, 2011 01:28 AM
gbeach
Jun 22, 2008 08:45 PM
