'02 Grand Voyager immobilizer problem
Hi,
My 2002 Grand Voyager will not start. It was OK two days ago but yesterday we had some low temperatures (-11 deg C) in the UK and this morning there appears to be a problem with the immobilizer. When I put the key in the ignition and turn it to the ON position all of the dash lights work OK, but the multifunction indicator light flashes a few times and the indicator/turn signal light flash twice. The engine will not start - I get a continuous clicking sound and all of the dash lights flash. I've tried both keys with the same result. Also sometimes whein I turn the key the A/C display comes on, other times not. If the A/C display is on there is no time display on the radio, if I turn the radio on the A/C display disappears. I've tried disconnecting the battery but no change. My obd2 code scanner cannot retrieve any codes - it indicates a communication error. I've tried getting an error code from the odometer but nothing shows. Any ideas anyone? Thanks. John |
sounds more like a flat battery
I had exactly the sam problem this morning. -15 deg C in Sweden. Very week starter engine and then no starter engine at all. Only a continuous clicking sound (ca 3-4 clicks per second). I tried to jump start the engine with cables from my other car. No response, just that annoying clicking.
I have now removed the battery at recharge it indoor (it is very cold now outside...). Let's hope it will work. Any other ideas? |
I put the battery back and had no problems to start.
Maybe I need a new fresh battery to avoid this problem. |
wrong thread sorry
