02 tc turn signals don't work
Old Jun 2, 2007 | 04:57 PM
evo8rcr's Avatar
Default 02 tc turn signals don't work
For some reason my turn signals and hazards don't work anymore, anybody wlse had this problem? or knows what it could be, I checked all of the fuses under the hood...Thanks
Old Jun 2, 2007 | 06:34 PM
evo8rcr's Avatar
Default RE: 02 tc turn signals don't work
any help anyone?
Old Jun 3, 2007 | 12:46 AM
U have either a IMP or Front Control module issue both are together but can be replaced by them self. the IMP is the fuse box up front.
Old Jun 3, 2007 | 03:12 PM
evo8rcr's Avatar
I checked the fuses?
Old Jun 3, 2007 | 06:09 PM
its not a fuse issue the head lights turns signles and a bunch of other things are controled by HIGH side drivers which is computer controled and not done by a computer telling a relay or a switch to turn on. look at the wire diagram and it will show u. The Multi function switch just tells the computer that it wants teh flashers or the turn signles to come on and the same computer will tehn tell teh lights to do as requested. 9 times out of 10 i have seen the IMP or the Front controler to make this issue happen.
[IMG]local://upfiles/1033/548ED8F6011C4CB8B154E43FB8608056.gif[/IMG]
[IMG]local://upfiles/1033/40393BF8138A494D9D424FCB9218B80E.gif[/IMG]
Old Jun 3, 2007 | 11:59 PM
evo8rcr's Avatar
call me a novice but how do I fix this issue?
evo8rcr's Avatar
Old Jun 4, 2007 | 08:06 AM
depends on how much u are willing to spend with out any tools.
U can guess the easy and less expensive part is the multifunction switch but i hardly ever see that go bad.
Then u have the IPM and Front Controler around 200 to 300 each.
Old Jun 4, 2007 | 12:56 PM
evo8rcr's Avatar
where is the multifunction switch located, and how would I test it? I believe I have the IPM do you know how to test, which ever it is I have to fix it regardless of cost, cheaper is better though
Old Jun 4, 2007 | 04:58 PM
take it to the dealer if u want a correct fix done. Only they have the ablity to look at the input and outputs from the multi function switch and what is commong out of either the front controler or IPM.
