-   Chrysler Voyager & Town & Country (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/)
-   -   '03 Town and Country cooling fan relay problem (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/03-town-country-cooling-fan-relay-problem-34872/)
TiredOldMan Oct 21, 2023 01:48 PM
Our T&C started overheating Thursday. After letting it cool an topping off coolant, It took about 10 min for it to climb almost to the red. Replaced the thermostat, and it went 4 miles or so before getting hot. Noticed only 1 fan working when AC on. Let it cool and made it another 3 miles home. Swapped the 40 amp cooling fan fuse with the power window fuse and it operated the windows. ran 12 volt directly to the 2nd fan and it ran. A friend came over and used his scope to operate both fans. He then pressure tested the system and found an air leak at the restrictor valve. I replaced that along with the hoses on both ends of it. Started it up , both fans worked. Drove it less than 2 miles and temp went almost to the red again. Fans not working. It only took about 5 minutes for the temp gauge to go back to normal( just below 1/2) which seems faster than I expected. Coolant was bubbling back through the reservoir. After letting it cool once again, it took approx 1/2 gallon to bring the coolant level back to top of radiator so I expect an air bubble in the system. I put the van on ramps to try and lift the front end which I saw somewhere might help with the bubble issue.
TiredOldMan Oct 21, 2023 01:53 PM
My bad, I wasn't finished with first post....
I am trying to test the cooling fan relay and had an issue trying to disconnect the wiring connector. The red locking tab broke off and now I can't disconnect it. Can I just get in there and break little pieces off or is there an easier way to take it off?
https://cimg0.ibsrv.net/gimg/www.chr...57e1dc8f2c.jpg
CHRYSLER TECH Oct 22, 2023 06:00 PM
use a pick to push it from behind or use the same pick to dig it out from the front.
