'05 Town & Country Harmonic Balancer Install
Old Jan 26, 2010 | 01:16 PM
drewfarns's Avatar
Default '05 Town & Country Harmonic Balancer Install
I'm trying to install a new harmonic balancer. The install kit I rented from Autozone wont work. The adapters are too big in diameter and not long enough to reach the threads inside the crank snout. Does anyone know where I might find the correct tool for installation? Thanks, Drew
Old Jan 27, 2010 | 06:10 AM
22chrysler's Avatar
I never needed a tool for this... I tap it on with a brass hammer to get it started on the shaft making sure it's square on the shaft (meaning straight/true), then use a bolt with a couple washers to draw it into place. Usually I can just use the original bolt. I grease the washer(s) and pulley surface to reduce friction when pressing the pulley on
addendum... I should clarify "brass hammer...tapped" because I'm sure someone will want to start an argument that hitting on these parts will damage the pulley, crank and thrust bearing... the key word is TAPPED not whaled, beat, pounded. I tap the pulley with a brass hammer which is softer than the casting of the pulley as not to fracture or damage the pulley. Tapping the pulley on the crank snout will ensure it's started on the crank straight and not cocked/crooked
jrp27540
Jul 11, 2015 10:49 PM
ktrent
Mar 30, 2012 06:33 PM
ponch37300
Feb 12, 2012 09:24 PM
iggy75
Cirrus & Breeze
Nov 11, 2006 10:27 PM
onerchprk
Other
Oct 29, 2005 06:23 PM
