08 town and country won't start
Old Apr 21, 2016 | 09:30 AM
rubles23's Avatar
Default 08 town and country won't start
I have an 2008 T&C 4.0 engine and it started running rough and shutoff a few times but was able to make it home. Drove like 5 miles this way. Now it won't start. Turns over fine. Have several codes P0300, P0016, P0404,P0406. I'm not sure which direction to take. I did replaced the crankshaft sensor and bought a camshaft sensor but can't find the location of the cam sensor? My wife said it did this a couple months ago but started back up and ran fine after that? It also a few months back started blowing the horn, wipers on, washing fluid spraying, lights flashing. But after I put a new battery in it hasn't happened again? Any help would be greatly appreciated. Thanks
Old Apr 21, 2016 | 12:09 PM
georgef's Avatar
Which engine does your van have?
Old Apr 21, 2016 | 12:30 PM
rubles23's Avatar
4.0 engine
Old Apr 21, 2016 | 12:31 PM
rubles23's Avatar
Found and replaced the cam sensor. It was underneath the alternator. But still no luck with it starting.
Old Apr 21, 2016 | 02:24 PM
Changing my story..
Old Apr 21, 2016 | 02:37 PM
rubles23's Avatar
Back in the fall it blew a heater core line and sprayed coolant all over the egr. So what your saying makes sense. Now if I plug off the egr will it fire? Or do I need to replace egr ? Also just pulled the plugs and they look wet and black. So I will replace those as well.
Old Apr 21, 2016 | 03:57 PM
Yes 404/406 refer to EGR valve and its possibly sticking. Think you have an electronic one, if you have, the EGR notes its position as been out of cue and sends signal to ECU which stops starting.
Old Apr 21, 2016 | 04:47 PM
rubles23's Avatar
Thanks... Ordered an egr valve. Will be here tomorrow afternoon and I will post the findings.
Old Apr 22, 2016 | 12:06 PM
rubles23's Avatar
Installed new EGR valve and new plugs. Still doing the same thing. Acts like its out of time. Could someone help me with checking the timing? Thanks
Old Apr 22, 2016 | 02:14 PM
Not much to go by here P0016 is Oxygen sensor. Misfire detected are your coils ok.
Now the EGR does it need Initialised I wonder as its electronic, is it electronic with a plug on it or is it actuated by outer source.
