1999 T&C engine knocking??
my 3.8l engine is making a knocking noise at idle when the engine is cold. When i hit the gas or once it warms up the noise goes away but then when i turn on the A/C the knocking noise returns. My oil level is fine. Any ideas?
Originally Posted by juicemandan
(Post 30873)
low oil pressure bad water pump cracked flex plate crank pulley tensionser pulley idler pulley alternator bearings a/c compressor rocker arms cracked piston worn rod bearings worn main bearings worn cam bearings timing chaing lifters could even be the Canister Purge valve |
hey thanks for nothing! i was just wondering if this was a common issue and maybe someone had it happen to them before and could lead me in the right direction. Thats the point of a forum right? not to tell people "well it could every part of your engine"
The whole prob with noise is that U cant hear it over the internet what some thing sounds like to u maybe different to an expert understand?
Anything that moves can make noise. |
(Post 30923)
Anything that moves can make noise. WHAAAAAA my car is broke WTF is wrong and why don't you fix it for me!!! I demand you GIVE the correct answer... NOW geez... some people |
loose nut behind the wheel?????
I knwo the post is old was it the famous flywhell problem? I thought it was my a/c compressor and changed it for nothing. Turn out my 2nd guess was right fly wheel
