1999 T&C engine knocking??
Old Sep 26, 2009 | 09:32 AM
juicemandan's Avatar
Default 1999 T&C engine knocking??
my 3.8l engine is making a knocking noise at idle when the engine is cold. When i hit the gas or once it warms up the noise goes away but then when i turn on the A/C the knocking noise returns. My oil level is fine. Any ideas?
Old Sep 26, 2009 | 01:09 PM
22chrysler's Avatar
Where do you want to start... theres a couple hundred things it 'could' be.
low oil pressure
bad water pump
cracked flex plate
crank pulley
tensionser pulley
idler pulley
alternator bearings
a/c compressor
rocker arms
cracked piston
worn rod bearings
worn main bearings
worn cam bearings
timing chaing
lifters
could even be the Canister Purge valve
Old Sep 26, 2009 | 04:22 PM
hey thanks for nothing! i was just wondering if this was a common issue and maybe someone had it happen to them before and could lead me in the right direction. Thats the point of a forum right? not to tell people "well it could every part of your engine"
Old Sep 26, 2009 | 05:34 PM
The whole prob with noise is that U cant hear it over the internet what some thing sounds like to u maybe different to an expert understand?
Anything that moves can make noise.
Old Sep 27, 2009 | 03:57 PM
22chrysler's Avatar
WHAAAAAA my car is broke WTF is wrong and why don't you fix it for me!!! I demand you GIVE the correct answer... NOW
geez... some people
Old Sep 28, 2009 | 04:56 PM
shawnsdad's Avatar
loose nut behind the wheel?????
Old Apr 11, 2010 | 07:13 AM
karayj's Avatar
I knwo the post is old was it the famous flywhell problem? I thought it was my a/c compressor and changed it for nothing. Turn out my 2nd guess was right fly wheel
edward2020
Aug 19, 2017 05:04 PM
ladisgsx
Nov 16, 2014 08:20 PM
Mad-MF
Jan 13, 2011 04:34 PM
tarquin100
Feb 21, 2010 09:46 PM
z06 hellcat
Oct 13, 2008 11:31 PM
