2.5 CRD Manuel Gearbox oil change
Old Dec 20, 2017 | 03:06 PM
TomC's Avatar
Cool 2.5 CRD Manuel Gearbox oil change
Hi Guys
I have searched this subject and had some conflicting opinions on the type of oil to use. Some recommend ATF but only in auto box etc.
therefore I would like to know
1) what is the correct fluid for a Manuel box
2) where is the drain plug
3( where is the filler plug
I did have the full Manuel as a PDF but can no longer find it. I did lose an hard drive a few years ago so it may well have been on there
Old Dec 22, 2017 | 06:34 AM
dieselvoyager's Avatar
Drain plug is below dif housing.
Filler plug is a black rubber/plastic plug just pull it out , No threads .
Use ATF+4 around 2 litters , I use to set the front wheels on blocks to raise the front a little . Then is easy to access the filler hole and it's possible to fill a little extra oil in to the trany .
Old Dec 22, 2017 | 06:35 AM
Red arrow is filler plug !
Old Mar 8, 2018 | 02:03 PM
TomC's Avatar
Many Thanks dieselVoyager only just getting round to it now as weather has been a major problem here
recepomac
Apr 15, 2015 12:24 AM
recepomac
Apr 14, 2015 07:53 AM
mike grand voyager
Feb 24, 2015 05:54 AM
flaxman
Sep 5, 2011 02:10 AM
voyager_dan
Dec 7, 2010 01:52 PM
