2000 -T&C. 2 Big problems, please help
Old Nov 26, 2010 | 09:57 PM
rickhuntersv's Avatar
Default 2000 -T&C. 2 Big problems, please help
Prob# 1:
-The RPM gauge goes almost 500 RPM and the computer (I think) try to compensate and accelerates almost over 2000 RPM, this happen a couple of times, but suddenly, the computer can not keep the RPM and fall lower than 500 and the engine turns off. When I accelerate with the pedal the RPM never get over 3500 RPM and starts to make a little cuts(this is wile parking).
- Some times the problem above happen while I´m driving and I losse power, with the acceleration pedal all the way down can not get more than 30 Mph. If I want to go faster I have to start pushing the pedal very quickly with out stop.
Some times the problem never happen and I can drive normally.
Prob# 2:
- The fans (2) in front of radiator do not work when I turn the A/C on and a few seconds after the little pressure valv over the A/C compressor start releasing the pressure an leaking the gas. This stops when I turn the A/C off. The fans work just fine when the engine is hot enough.
I called a mechanic and replaced the fuel pump and fuel filter but it did not solve the problem #1 I still have the problem.
For the problem #2 He replaced a little module, the one thar is below the fornt light near the radiator, and did not solve the problem. I paid him $450 and now his not answering his phone.
Can someone help me with an advice?
Thank for you support!!
Old Nov 26, 2010 | 10:06 PM
check engine light on for prob 1?
Old Nov 26, 2010 | 10:14 PM
Yes, but the mechanic said that the code is related emission problem. He used a little scaner to read the code.
Thank for yor soon answer.
Old Nov 26, 2010 | 10:19 PM
TNtech's Avatar
You need to find a technician instead of a grease monkey-parts changer with a Harbor Freight scan tool. Anything beyond 1996 needs someone who has the mental capacity to understand how cars with computers work. They are a dying breed.
Off the top guess from me without seeing the car is that the A/C pressure transducer (high side pressure sensor) is reading incorrectly. It is located under the wiper cowl on the passenger side attached to the A/C line. Should be a roundish grey connector. Understand that Codes are not always the cause of your problem, they are often only a result.
drag777
Mar 21, 2013 12:54 PM
chris565
Jul 24, 2012 04:44 AM
chris565
Jul 16, 2012 11:53 AM
lmaternick
Jul 6, 2012 07:56 PM
stelyyy
Sep 3, 2007 12:45 PM
