2000 T&C
Old Jul 26, 2007 | 11:30 AM
robbiedog's Avatar
Default 2000 T&C
Lookingat a 2000 T&C with 80,000 on 3.3. Excellent condition. Anyone know of any hidden problems I should look for?
Thanks in advance.
Old Jul 26, 2007 | 10:25 PM
Stretch's Avatar
Default RE: 2000 T&C
Don't buy one with a leak(oil, Trannie fluid or antifreeze). If possible, get a local trade-in. Ask to see maintenance records if available. Look at antifreeze and A/C lines going to the rear of the car and see if they are heavily rusted. Look at the top of the strut towers in the engine compartment for heavy rust/deterioration. During the test drive listen for groaning from the front suspension when going slowly over a speed bump or something like that, may be bad sway bar bushings/links.
Try ALL the power equipment(windows, every door lock etc.) Remote door lock/unlock, wipers, all lights, turn signals. Gas tube supports for rear gate. Verify the A/C works on all speeds of both the front and rear blowers(if equipped), verify air comes out where it should, based on the control position(self explanatory). Make sure cruse control works. I still think it is the best cruse in the industry.
Just a few things that come to mind, there are some others that I am sure others can think of, some real pros here.
Old Jul 27, 2007 | 09:19 AM
robbiedog's Avatar
Thanks for the info. Got complete carfax on this and it has been meticulously maintained. No leaks or rust. Looks to be a "creampuff"
