2001 Grand Voyager Speedo flip round
Hi,
The speedometer needle has some how spun round and now of course is stuck behind the pin. How do you move it round ? I have noticed that with the engine switched off the needle points vertically down, upon ignition it moves left, but gets caught by the pin, so I'm hoping this is a glitch and not indicative of another problem. Any help is much appreciated. |
Slow down!
I thought they were governed at 114mph! |
To activate the Self-Diagnostic program:
With the ignition switch in the OFF position, depress the TRIP ODOMETER RESET button. Continue to hold the TRIP ODOMETER RESET button until Sof and a number (software version number (i.e. Sof 3.2) appears in the odometer window (about five seconds) then release the button. If a fault code is present, the cluster will display it in the odometer display. When all fault codes have been displayed, the cluster will display “end” in the odometer |
Hi,
Followed instructions, thanks. Needle is now in the correct place. When I reset the trip, it showed the following:- 1. Sof 4.0 2. E100.5 3. End It then did a series of tests, and the needle was returned to the correct place. Did I miss a step ? Is there an actual error ? |
| All times are GMT -5. The time now is 11:25 PM. |
