2001 Grand Voyager Speedo flip round
Old Aug 11, 2010 | 08:56 AM
flare's Avatar
Default 2001 Grand Voyager Speedo flip round
Hi,
The speedometer needle has some how spun round and now of course is stuck behind the pin. How do you move it round ?
I have noticed that with the engine switched off the needle points vertically down, upon ignition it moves left, but gets caught by the pin, so I'm hoping this is a glitch and not indicative of another problem.
Any help is much appreciated.
Old Aug 11, 2010 | 09:27 AM
gn300's Avatar
Slow down!
I thought they were governed at 114mph!
Old Aug 11, 2010 | 02:23 PM
To activate the Self-Diagnostic program:
With the ignition switch in the OFF position, depress the TRIP ODOMETER RESET button.
Continue to hold the TRIP ODOMETER RESET button until Sof and a number (software version number (i.e. Sof 3.2) appears in the odometer window (about five seconds) then release the button. If a fault code is present, the cluster will display it in the odometer display. When all fault codes have been displayed, the cluster will display “end” in the odometer
Old Aug 12, 2010 | 07:04 AM
flare's Avatar
Hi,
Followed instructions, thanks. Needle is now in the correct place.
When I reset the trip, it showed the following:-
1. Sof 4.0
2. E100.5
3. End
It then did a series of tests, and the needle was returned to the correct place.
Did I miss a step ? Is there an actual error ?
Evertb
17
Apr 21, 2022 04:00 PM
71grande
Jun 1, 2011 09:21 PM
scousedave10
Mar 25, 2011 02:46 PM
thomasjtsi
Oct 9, 2007 05:30 PM
