2001 T&C Limited Auto Temp. comtrol problem
Old Nov 23, 2012 | 02:10 PM
F150's Avatar
Default 2001 T&C Limited Auto Temp. comtrol problem
My daughter was using our van and the battery died, They jumped it and took it to AutoZone and had the battery replaced, Now when you start it it blows on high thru the defrost with the ATC on. If you change the selector to floor it stops blowing out the defrost and blows out the floor until you turn the ATC power off then it goes back to high thru the defrost. Is there a reset that needs to be done or has something gone wrong. Thanks in advance.
Old Nov 23, 2012 | 02:18 PM
Raptor 07's Avatar
Either disconnect the negative battery cable for a few minutes or try the procedure in post #7 of this thread: Tizzy1 and others DIY information - DodgeForum.com
If your A/C isn't working don't perform the cool down test.
Old Nov 24, 2012 | 10:27 AM
F150's Avatar
Try both , Just blows on high now
Old Nov 27, 2012 | 04:30 AM
F150's Avatar
Problem solved, Was the blower resistor
MarkCNY
Sep 20, 2016 11:37 AM
steveatpa
Aug 17, 2015 11:13 AM
adourov
Sep 23, 2010 01:00 PM
kentchris
Apr 30, 2009 05:30 PM
Bobby721
Nov 19, 2008 08:21 AM
