2001 T&C LIMITED Battery Drain over night
Old Oct 13, 2016 | 06:13 PM
Me745011's Avatar
Default 2001 T&C LIMITED Battery Drain over night
Hello everyone. Im new to the site. I have a question that hopefuly you guys can help me out with. I have a 2001 T&C that the battery drains over night. Ive replace the battery twice, so I know its not the battery, have NOT had the Alternator check yet. I performed an AMP draw across the battery when everything is off in the van and I draws 1.295A. I wait for a few to let the system go in to sleep mode and the amps go down to 0.291A. I know that a draw over 50mA is not good and it will drain the baytey.So I started to pull fuses and there was only one fuse that I pulled that lowered it to 0.040A and that was the 40A fuse for the BCM. Do you guys know what components the BCM run so I can go down the line and troubleshoot each component. Or is this a sign that my BCM is bad or going bad. They van is drivable and everthing works, like the radio, power windows, sliding doors, light, etc. Anything info would help. Thank you very much.
Sebring007
Jul 20, 2015 09:24 PM
kj981300
12
Jul 22, 2014 01:26 PM
jgr7
Cirrus & Breeze
Oct 8, 2011 10:54 PM
Dave Rogers
Mar 1, 2009 08:32 AM
