2001 T&C Limited rear door does not open automatic..
Old Jan 7, 2008 | 03:26 PM
jquinones's Avatar
Default RE: 2001 T&C Limited rear door does not open automatic..
ok I see,
I try to close the door with the remot or inside the van and doesnt work too. Is that normal the door be very light to open or close by hand? Like the sides door if you try with your hand is very havy to open or close ( so I use a lot the remote and inside the van to open/close the side doors.)
thanks
Old Jan 7, 2008 | 03:27 PM
jquinones's Avatar
Thanks a lot MOE, I like pictures, I don't like to make mistakes.
I'll try that MOE.
Old Jan 7, 2008 | 03:28 PM
jquinones's Avatar
thanks a lot MOE I'll try that, I like pictures
thanks
Old Jan 7, 2008 | 03:37 PM
moe's Avatar
moe
there was also a flash that was done at the same time ,heres the tsb #23-035-00,ask your dealer since thats when the flash has to be done from.moe
Old Jan 7, 2008 | 04:46 PM
  #15
jquinones's Avatar
Yes correct, it beeps (like truck when it gives rear), lights flashes and locker opens, the only thing that does not happen is the trunk door that won't lift.
Old Jan 7, 2008 | 07:12 PM
  #16
dan194's Avatar
Your problem sounds exactly like mine was.Try the shims and let us know how you made out.Start with one steel washer on each screw behind the rubber block and against the van body.If needed try two washers on each screw.Good luck
[align=left] [/align]
Old Jan 9, 2008 | 12:39 PM
  #17
jquinones's Avatar
I did shim like you said, of 1/4 of a inch but nothing!! did not work!! now the door pops even harder but not lifting!!
any other idea?
thanks guys
Old Jan 9, 2008 | 03:06 PM
  #18
moe's Avatar
moe
there is a lift gate module that might be failing on you,i beleive its in the rear quarter on drivers side.
Old Jan 9, 2008 | 05:27 PM
  #19
jquinones's Avatar
correct, but how can I fix this?
thanks
Old Jan 14, 2008 | 04:12 PM
  #20
Rick99's Avatar
ORIGINAL: jquinones
any other idea?
thanks guys
This sounds exactly like mine. If I were you, I'd try replacing the latch on the liftgate. The part will cost you less than the diagnostic at the dealer. The dealer would have the benefit of a DRBIII scan tool which allows them to watch the switch states from the comfort of the driver's seat. However, if you really want to test it, you could take the interior trim off the liftgate, go inside with an ohm meter and manually check the state of the pawl switch when the door is in full closed position and then again when the door is popped. If the switch state does not change, you have verified the problem.
Maybe someone here can post a pin-out of the connector on the latch module that will show which pins to test.
Again-- after the liftgate control module pops the liftgate, it must receive the correct signal from th pawl switch indicating that the door is popped before it starts the opening sequence.
