2001 Voyager rear wiper
I've just boughta 2001 (new model for the year) CRD LE Voyager. The rear wiper is not working - the light comes on on the switch when in either 'on' position - any suggestions where I start to track this down?
Additionally, I can't open the rear door using the outside latch (is this an electronic switch or a mechanical linkage), so have to use the key to open it - again, any ideas gratefully received.
ORIGINAL: Merlin
Hi
sounds like you will need a new wiper motor and a new tail gate switch (yes it is an electronic switch)
Hi
Many thanks - I can see I've come to the right forum
Easiest way that i know of to check this is to call down to your local chrylser dealer and ask the parts guys. Almost every parts guy I've ever dealt with has been willing to help out with questions like this.
ORIGINAL: dodgetech1
One more question - does anyone know exactly what breaks with these motors? I've found one motor on ebay in the UK for about £100 ($150) but if it's something simple like the bushes worn out, then it may be repairable.
I would check wiring. It seems a little fishy that both parts would break ( it's possible but less likely than a wiring problem) Maybe the connector for the tailgate is not connected or a wire is cut.
ORIGINAL: JeepAndAVan
Just to bring this back up again - can anyone tell me how to remove the plastics from inside the rear tailgate (2001 model) without damaging them?
screws around the bottom end then just clips in. bottom half goes under the top half but you don't need to take the top half off just unclip the first bit on the join then the bottom half will come away.
