2002 2.5 CRD Cambelt change
Old Jun 5, 2010 | 02:52 AM
adeel43's Avatar
Default 2002 2.5 CRD Cambelt change
Hi,
I'm in SW19 South London and need to get the belts and tensioner changed - would you recommend I get the waterpump done also? Car is on 141,000 and only came with part history and cant confirm if it has been done or not.
Also where is a good place to get this done - from what I can see it is quite an expensive job!
Adeel
Old Jun 5, 2010 | 09:31 AM
Merlin's Avatar
Hi
Water pump in not a common failure and it's a lot more of a job to do the pump as you will need to lock the cams properly instead of just holding them in-place. If it was mine I wouldn't do the water pump as it goes from 2 hours to 5 hours time wise, but it is better safe then sorry at your mileage.
Old Jun 5, 2010 | 12:44 PM
adeel43's Avatar
Thanks Merlin, although I seem to have a bigger issue now - was driving around Hampton today and the car lost power and stalled, getting home to Wimbledon this happened around 25 times and after much frustration (have only had the car for two weeks) I wish I had never bought it and needless to say my wife is not impressed.
Any ideas from the experts - at idle it is very rough when cutting out and happens from a stanstill but never when moving.
Thanks in advance guys.
Old Jun 6, 2010 | 03:44 PM
Merlin's Avatar
do a search on here for P1130.
Old Jun 8, 2010 | 12:42 PM
dandy's Avatar
Change fuel filter, under car at rear. I've had this a few times, normally in the winter. Now I change it every September.
Kind Regards
Old Jun 8, 2010 | 04:28 PM
adeel43's Avatar
Thanks Dandy, I actually ordered a new filter today but when I went to start the car today it just clicks and wont start - I moved it this morning and rechecked the codes via the key method and left till I got home from work but its completely dead and I will be too if I dont get this sorted!
Old Jun 9, 2010 | 12:36 PM
actd's Avatar
I would have thought that if it's just clicking when you try to start it, then the battery is dead.
Old Jun 10, 2010 | 07:37 AM
adeel43's Avatar
Charged the battery after realising that when I was cleaning it I left the interior lights on must have drained it for 3 hours!
On to fixing the problems I have found this company round the corner from me seem to have dealt with this issue before and the car goes in on Tuesday next week for diagnostic and they said they would test the injectors and the MPROP valve. Seem to be genuine people and come highly recommended from other garages in the area when I was doing the rounds.
Watson (Diesel) Limited
Ronian Works
Elm Grove Ind. Est.
Wimbledon.
SW19 4HE.
U.K.
Tel: 020 8879 3854
Tel: 020 8879 3861
Will let everyone know how I get on with my issues!
Old Jun 11, 2010 | 12:06 PM
dandy's Avatar
Have you changed fuel filter yet? Easy job and if it solves the problem it saves you money. This has always been my car problem, had it a few times, dirty fuel, cold weather - I have same model 2002 2.5 CRD.
Anyhow - best of luck.
Old Jun 13, 2010 | 03:57 PM
adeel43's Avatar
Got the filter in the post yesterday and just need to know how to fit it - I'm sure I can do it just need a handy guide to show me how!
