2002 2.5 crd lx cuts out ( help needed)
Old Mar 15, 2011 | 02:26 PM
scousedave10's Avatar
Exclamation 2002 2.5 crd lx cuts out ( help needed)
hi i just brought a 2002 voyager 2.5 crd lx with 126k on the clock
i took it for good run out and was doing apx 70 mph and the car cut out on me i managed to get to hard sholder and turn key off then restart the engine,
i took off again and within 1 mile i happend a again so repeated what i done above but it took 2 turns of key to start
it was fine for rest off my journey apx 45 miles
on way back it did same cut out 2 times then fine
i have just took it on motorway and done 70mph noked it down to 4th and accelerated and it cut out again
i have noticed that my number 2 injector is blowing as around the housing is full soot ect and you can feel the air presure when you put hands above
im after info on what it could be as i read on hear and sounds like the p1130 fault
last thing would this fault affect my fuel comsumption
thanks in advance
Old Mar 16, 2011 | 04:38 AM
glowplug's Avatar
Switch you car from accessory to on (where the light scome on but do not start) 3 times in 5 secs ending in the lights on position. After a few seconds the read out will show you an error code e.g. P1130.
Come back and tell us what the code is as that will give guidance to what is wrong with your car.
Old Mar 16, 2011 | 02:24 PM
hi just did that ( worked out had to be on trip mileage page to show code )
the code was p1130
what would this indicate
Old Mar 16, 2011 | 03:46 PM
glowplug's Avatar
Its a fuel pressure code. Do a search on this forum, there is plenty about it. I believe that it is sometimes due to the actual fuel pump and other times a relay. Merlin, who is a Chrysler mechanic, has writen plenty about it in the past.
Old Mar 25, 2011 | 02:42 PM
just update i had it looked at by garage i got it from and they have said that number 1 injector is faulty ( they done leak off test ) only issue now is they can not remove it so i told them to stop work il remove it ( looking for tool found few people who hire them out but going to take 2 weeks min ) car runs fine tho
so fingers crossed i get it out soon
Old Mar 26, 2011 | 01:24 AM
glowplug's Avatar
Others have done this. Have a search through the forum and you will find info on the tool.
Old Mar 31, 2011 | 06:05 AM
removed all injector fine fault gone now but today 3/4 injector was blowing air+ fuel from what looks like the base off injector i removed agian , where injector goes into and the botton half inject was coverd in fuel ( im hoping it just the copper seal order set off 4 of chrysler
Matt077
Jan 25, 2014 02:40 PM
jonjamesbuckley
Sep 22, 2012 08:50 AM
crosbo
Aug 18, 2012 10:58 AM
Oxnardboy
Apr 9, 2007 02:55 PM
Oxnardboy
