2002 Town &Country blower fan
Old Mar 29, 2008 | 02:04 PM
rkluck's Avatar
Default 2002 Town &Country blower fan
I have a 2002 Town & Country with climate control and the blower runs on high whether or not theA/C system is on or not.
Does this sound like a bad blower resistor module?
Old Mar 29, 2008 | 03:14 PM
Rick99's Avatar
Default RE: 2002 Town &Country blower fan
Yes, sort of. If you have the automatic temperature control (where you set the temperature digitally), then you don't have a blower resistor but something called a "blower control module". It doesn't contain resistors-- it has electronics that receive digital commands from the control head and then quickly cycles the power on and off to control fan speed. I've had two of them die on my van-- one died with the fan on high (even if the climate control is turned off) and the other died with the fan off.
The main difference from your perspective is that it's a lot more expensive than a resistor block-- I paid about $70. Fortunately it's easy to replace though. Just open and empty the glove box, squeeze the sides together and let it hang down. You'll see two connectors going into the HVAC box-- take the connectors off, then use a phillips screwdriver to remove the two screws that hold the control module in place. Put the new one in and you're done.
Brian24
Mar 7, 2014 03:49 PM
nickw23
Aug 26, 2012 03:46 PM
Numanchi
Aug 26, 2011 06:40 PM
colbertgang
Apr 26, 2009 09:30 PM
300winchester
Mar 29, 2009 02:48 PM
