2002 Town and Country Fan problem
I have a 2002 Town and Country van, the front fan only works on high, any ideas, ? Thanks in advance
:rolleyes: |
If manual system-- blower resistor
If ATC-- blower control module There's lots of info-- try a quick search. |
Most def. blower resistor..I just replaced mine and everything works fine..Disconnect neg.(black) terminal on battery, empty glovebox push sides of glovebox in and glovebox swings down. The resistor is right in front of you..Disconnect the 2 harnesswires, then 2 screws and slide new one in, plug in and done. I got mine at O'Reilly Auto Parts for $14.00..Good Luck!!
thanks
Thats what I needed, a good definition on where to fix, thanks much
MGM |
Originally Posted by 300winchester
(Post 26099)
MGM Philip |
drop the fan and get the trash that is inside there.
(Post 26107)
Can you please tell me how to get access to the fan and clean the trash out...I tried taking the bottom of the blower motor housing off, but because of access restraints I stopped. Can you point in a different direction or some instructions for a simpler task..Thank you for your help!!:) |
what year fan do u have?
(Post 26185)
never mind live with the noise U haft to take out the dash and hvac housing to remove the blower.
