2002 Voyager AC recalibrate?
May 22, 2011 | 01:53 PM
Hi there, can anybody tell me if there is a calibration mode for the climate control on my 2002 Grand Voyager and if there is how to perform the operation. Many thanks in advance.
May 22, 2011 | 05:49 PM
what is wrong that you want it recalibrated????
May 23, 2011 | 04:29 AM
Thanks for responding, the reason i ask is because it was not blowing out ice cold. I had it regassed at the weekend and still it isnt quite cold enough. There are no leaks in the system and i just remember that when i used to own a saab 9-5 i could push a sequence of buttons and it would recalibrate the system and give me fault codes if their were any. Reading this and other forums i know that the older model could be done but i cant find out any info on mine.
Many thanks
Simon
May 23, 2011 | 04:49 AM
sure its summin like set the ac to full open all vents and hold down the washer and ac button for approx 5 seconds
May 23, 2011 | 02:46 PM
ok...
REcal is for door position after a battery disconnect. Unless the LEDS are flashing at you, It wont do much...
Yes there is a diagnostic test..but it isnt a "Fault Code" based test..Its only pass or fail. Its called a Cool down Test. unfortunately, 2001 and later requires this test to be performed with a factory scan tool.
Now ..an interesting question which may change everything.....Is this a Diesel???
May 24, 2011 | 03:06 AM
Thanks for your answers. Sorry i should have put that it is a 3.3 petrol Grand Voyager
