2002 Voyager radio bezel & bezel removal
Old Feb 9, 2008 | 08:24 AM
antares's Avatar
Default 2002 Voyager radio bezel & bezel removal
I need help removing radio bezel in 02 Voyager so I can replace radio, any ilustrations or instructions would be greatly appreciated
Old Feb 9, 2008 | 11:02 AM
Default RE: 2002 Voyager radio bezel & bezel removal
REMOVAL [ol][*]Disconnect and isolate the battery negative cable.[*]Remove cup holder.[*]Remove trim panel above cupholder by pulling straight out.[*]Remove center instrument panel trim panel.[*]Remove screws holding radio to instrument panel.[*]Pull radio rearward to gain access to the back of radio (RADIO). CAUTION: Pulling the antenna cable straight out of the radio without pulling on the locking antenna connector could damage the cable or radio.[*]Disconnect the antenna cable by pulling the locking antenna connector away from the radio (ANTENNA TO RADIO).[*]Disconnect bolt holding ground strap to the radio (if equipped).[*]Disconnect the wire connectors from the back of the radio. [/ol]
Old Feb 12, 2008 | 07:26 PM
antares's Avatar
Thanks for info, sure do appreciate it, saved me a ton of trouble.
HemiAspen4me
Jan 2, 2013 12:20 PM
tbird2340
Aug 9, 2011 09:57 PM
kre8
Oct 25, 2007 03:14 PM
fcms2004
Sep 11, 2007 10:05 AM
kawser
Jul 8, 2007 09:58 AM
