2002 voyager wing and front bumper fit...Help!
Old Mar 16, 2013 | 06:56 AM
Nicko's Avatar
Default 2002 voyager wing and front bumper fit...Help!
Apologies if this is posted somewhere else, I did look but could find a post.
Any how my wife has had a fight with a concrete Ballard and her Chrysler has come off worse! I have a new front bumper with bracket and near side front wing to fit. The only problem is I haven't a clue were to start.
I've had a quick look around and can see a few bolts and have been told an hour or so to do "not a big job" any tips guides or advice would be much appreciated.
Wish me luck...
Old Mar 18, 2013 | 05:41 PM
Default Front Bumper fit..
No idea myself but think there's a video of the job on You Tube by one of those helpfull American chappies...
Goggs...
Old Mar 19, 2013 | 06:29 AM
Nicko's Avatar
Default you wuda thought...
Carnt seem to find one, checked town and country, voyager, fender, bumper all non starters.
was hoping this was going to be a straight foward job but judging on the lack of posts seems it might be a pain in the ar!e of a job that people just dont like to do? looks like the wing mirror has to come of and the inner wheel arch maybe...
Old Mar 19, 2013 | 07:17 AM
travelmad's Avatar
Default Fender
Front Fender Removal
(1)Remove headlamp housing.
(2) Remove mirror bezel
(3) Remove mud guard.
(4) Remove inner splash shield.
(5) Remove fender to fascia nuts.
(6) Remove outboard cowl grille/fender bracket screw and antenna right side only.
(7) Remove fender bolt to lower rocker panel.
(8) Remove fender bolt to lower cowl.
(9) Support/remove hood.
(10) Pull fascia away from fender.
(11) Remove bolts attaching fender to upper rail.
(12) Remove fender from vehicle
INSTALLATION
(1) Place fender in position on vehicle.
(2) From inside engine compartment, start the center upper rail bolt. install all the bolts attaching fender to upper rail and tighten.
(3) Install fender to lower cowl panel bolt.
(4) Install fender to rocker panel bolt.
(5) Place fascia into position.
(6) Install hood/remove support.
(7) Install outboard cowl grille/fender bracket screw and install antenna right side only.
(8) Install fender to fascia nuts.
(9) Install inner splash shield.
(10) Install mud guard.
(11) Install headlamp assembly.
(12) Check fender for flush and gap. (Refer to 23 -BODY/BODY STRUCTURE/GAP AND FLUSH -SPECIFICATIONS).
Old Mar 19, 2013 | 09:47 AM
Nicko's Avatar
Default thank you
I do not know what corner of the intertubes you found this information or if this is infact your own personal knowledge but you sir are a gentleman and truly must be some sort of forum Jedi?
let the instalation begin
Old Mar 19, 2013 | 10:04 AM
travelmad's Avatar
you know, if you ask the right people, it is possible to see many informative things
Alan mills
May 20, 2013 10:32 AM
ryaneb
Jun 11, 2012 10:34 PM
roofchopped
Mar 31, 2009 06:22 PM
discodaddy
Jan 27, 2009 05:30 AM
djimenez04
Cirrus & Breeze
Aug 2, 2007 03:29 AM
