2003 chrysler T & C intermittant high idle
Old Aug 16, 2011 | 10:57 AM
2003chryslerT&C's Avatar
Default 2003 chrysler T & C intermittant high idle
I have a 2003 T & C. It infrequently and intermittanly has a higher that normal idle when placed in neutral or park (approximately 1500 RPM). When it is in this mode the shift points of the transmission are also higher or I need to let off the accelerator to get the transmission to shift sooner (lower rpm). It recently had a vacuum leak that was fixed but the problem still occurs. It can occur 1 x a week to 2x a day. There are no codes present. 117,xxx miles 3.8 liter. Throttle body has been cleaned and no matter what you do to the throttle linkage it will not idle down. Then later it will idle as normal and shift as normal.
Any suggestions would be great
skers
Mar 6, 2014 09:06 PM
iansh
May 9, 2013 09:13 AM
J Wikoff
Feb 24, 2012 11:08 PM
jgronberg@sbcglobal.net
Jan 2, 2011 11:11 AM
sebringted48
Jun 7, 2009 04:27 PM
