2005 2.8 limited crd wiring diagram?
Old Jan 16, 2011 | 04:32 AM
Gasman's Avatar
Lightbulb 2005 2.8 limited crd wiring diagram?
Morning
Does anybody have a good wiring diagram on hard drive for my CGV 2.8 crd limited 2005 that can be emailed to me? it really must be current and have the ABS system available on it?
Old Jan 16, 2011 | 03:24 PM
Merlin's Avatar
connector pin out can be found here. http://dto.vftis.com/mopar/main.asp so you can make up your own. If you want me check anything I will but can not issue you a diagram.
Old Jan 17, 2011 | 12:10 AM
Gasman's Avatar
Question
Hi Merlin
Once again thanks, all I am really looking for is the ABS circuit, I really need to check the cables to the service connector and MIC from the CAB module, basically the ABS is still not talking so I am now thinking that their may be a problem with the PCI link through the IPM module but all the info that I have is not complete enough to run a full circuit test
Old Jan 17, 2011 | 01:04 AM
manh's Avatar
Talking
I have the same car as you do and I have used wiring diagrams from Dodge grand caravan which is basically the same car in terms of electronics. You can find all wiring diagrams here. http://www-5.dodge.com/bodybuilder/2007/rswdz.zip
Aid
Nov 2, 2012 09:42 AM
DrSpocks
Apr 3, 2012 02:13 AM
engwrc
Jan 12, 2008 08:46 PM
trueburton
May 18, 2006 09:08 PM
