2005 Grand Voyager Door Sensors
Bit of a random one here!
Is there any way to fool the system into thinking all the doors are closed when 1 is open?
In looking to use the vehicle to sleep in for fishing - this would require me to have 1 of the sliding doors open for quick exit on getting a bite. i have measured the draw if you lock the system with a door open and i believe the relevant module is still awake (1.6ish mAh draw).
If it helps at all its a 2005 Grand Voyager 3.3l V6 and I'm in the UK
Thanks in advance
Rob
Thanks in advance
Rob
If you lock the system while you are inside you will need to disable the internal movement detector for the alarm. In case you don't know, you can switch off all the internal lights with the rotary switch on the dash.
Rustydog
May 11, 2019 11:59 AM
error7
Jun 30, 2011 03:16 AM
clillington
Apr 8, 2011 04:46 PM
