2005 T&C Liftgate Issue
My lift gate will open with the fob, overhead console switch or key in the lock. However, it will not open if I push the switch (handle) on the lift gate. Since the handle is an electrical part, is there anything I should look for before I just run out and just buy a switch?
If you could locate the plug, I'd think you could use a meter set to ohms and see if, when you press it, the reading changes.
This switch?
01 08 Dodge Caravan Chrysler Town Country Liftgate Release Switch Mopar | eBay You could try plugging and unplugging it first. It's fairly inexpensive. Dorman makes one also. |
Originally Posted by Cheyne
(Post 96384)
This switch?
(Post 96384)
This switch?
01 08 Dodge Caravan Chrysler Town Country Liftgate Release Switch Mopar | eBay You could try plugging and unplugging it first. It's fairly inexpensive. Dorman makes one also. Update: Success! Yes the interior trim panel on the liftgate must come off. I would recommend removing it before removing the handle from the outside. It was fairly easy. The hardest part was disconnecting the harness, I am never quite sure how to unlock them, each one locks so different. By doing the harness first, you can take the handle off of the liftgate and bring it to a workbench to remove the wires from the harness (another type of lock) and the switch from the handle. Whole job should take about 45 minutes. For me the worst part was removing the old wires from the harness. That lock was the worst. Dominic |
