2005 T&C lightbuld - 3 zone Auto Temp Control
Old Sep 22, 2010 | 04:05 PM
adourov's Avatar
Default 2005 T&C lightbuld - 3 zone Auto Temp Control
2005 Town and Country equipped with the Infrared Three-Zone Automatic Temperature Control. The lightbulb that would light up the right side of the right most dial - feet / feet-defrost / defrost, along with teh recirc rocker switch - has burnt out. How do I replace the bulb?
I was able to remove the entire unit from the dash. There are 4 Torx #15 screws that hold the two pieces together, along with I think 5 pressure clips. Taking out the screws and "jiggling" the pressure clips did not actually get the two pieces apart, yet it seems like the rocker switches on the front start to wiggle.
Thanks !
Alex
Old Sep 23, 2010 | 12:09 PM
moparrh's Avatar
Default Light bulbs
Did you remove the three control *****? There is one more torque screw on the inside that will have to be removed in order to seperate the circuit board. Disconnect the small wiring connector in the corner. The bulbs are soldered into the circuit board.
Old Sep 23, 2010 | 12:19 PM
adourov's Avatar
Default 3 *****
I have not tried to remove the *****, but guessing from your reply that they are removable. How? Simply by pulling? I sure as heck don't want to break anything and have a $500 circuit board / panel to buy !
Old Sep 23, 2010 | 01:00 PM
moparrh's Avatar
Default Light bulb
Yes, they just pull off.
MarkCNY
Sep 20, 2016 11:37 AM
ReDxSiLLy
Jul 1, 2015 08:49 AM
F150
Nov 27, 2012 04:30 AM
kentchris
Apr 30, 2009 05:30 PM
Bobby721
Nov 19, 2008 08:21 AM
