2005 T&C Lug Nut Torque?
Old Nov 6, 2006 | 11:46 AM
flash9's Avatar
Default 2005 T&C Lug Nut Torque?
What is the recommended Lug Nut Torque for a 2005 T&C Alloy Wheels?
Old Nov 7, 2006 | 05:27 AM
webbee's Avatar
Default RE: 2005 T&C Lug Nut Torque?
AutoZone spec's for the 4th gen, list 100 foot pounds for all wheel styles.
Old May 20, 2015 | 05:25 PM
bowlingss's Avatar
Discount Tire uses 110 and the manual I have-Hayes says 100 also.
Bill
Old May 20, 2015 | 07:14 PM
georgef's Avatar
It's 95 ft lbs according to the "WHAT TO DO IN EMERGENCIES" section of the 2005 owners manual:
11. Finish tightening the lug nuts. Push down on the
wrench while tightening for increased leverage. Alternate
lug nuts until each nut has been tightened twice. Correct
wheel nut tightness is 130 N·m (95 ft. lbs). If in doubt
about the correct tightness, have them checked with a
torque wrench by your dealer or at a service station.
You can download Chrysler owners manual at: http://www.chrysler.com/en/owners/manuals/
Old May 21, 2015 | 02:08 PM
Or if your a tyre depot its...Drrrrrrrrrrr...Drrrrr..Drrrr...III...Answere d by...Bloody hard job to get it off as you jump on your torque bar with scaffold tube attached.
Old May 21, 2015 | 04:12 PM
darkcild101's Avatar
Wow you mean people actually measure this. I just use force till it feels tight
Old May 21, 2015 | 05:50 PM
If only you ever touch your wheels, that's fine but ......................
Idiots in general garage use a general windy impactool, which they need absolutely do need for stubborn high torque bolts on cars. Unfortunately they always seems to be left set at the upper end of 25-340 Ft Lbs. When you come to take off a wheel you have no chance without a good 24" 3/4” drive breaker bar or a piece of scaffee tube as an extension lever. Personally a half decent new tech battery impact is good for about 200 Ft Lbs and should be good enough for any wheel stud.
ttbnie
Dec 20, 2012 01:33 PM
jjmeyer01sebring
Feb 19, 2011 12:57 AM
SDHUSKER
Jan 10, 2010 04:41 PM
narrowroad
Mar 7, 2008 07:06 AM
fyrepower
Nov 28, 2007 03:28 PM
