2006 Gran Voyager red light on dash
Old Aug 22, 2013 | 09:45 AM
jeremydixon's Avatar
Default 2006 Gran Voyager red light on dash
2006 Grand Voyager
Red light PERMANENTLY illuminated on the dash under the temp gauge.
Car is running fine. I have the grey key.
Have searched and discovered a possible like to a SKIM issue.
I have tried locking and unlocking with key and spare key on both drivers and passenger door. Also on boot / trunk.
I have also tried hitting the dash and doesn't look like a loose connection.
I have done the on off, on off key turn and the system reports no faults.
Can anyone help me with this?
Old Oct 3, 2013 | 07:16 PM
Newtonn's Avatar
Have same prob myself... Still trying to find what's causing light to appear.. I also have the immob light on and also the airbag...
Old Oct 4, 2013 | 02:25 AM
doug45601's Avatar
Bad clock spring.
Old Oct 4, 2013 | 06:07 AM
Newtonn's Avatar
Originally Posted by doug45601
Bad clock spring.
Thanks Doug.... You could be right.. Will be attempting to pull the codes over the next few days to confirm....
Old Oct 4, 2013 | 08:10 AM
Breaking300's Avatar
The clockspring is probably the culprit...
CLOCKSPRING for 2003 Chrysler Voyager|5082050AC
It's part #2 in the diagram (it's the same part on your car as well, I checked)
Old Oct 5, 2013 | 10:16 AM
Newtonn's Avatar
Thanks - will definitely check that out. however it also looks like I might have aftermarket alarm installed - that may be the reason for the red light on the dash that isn't standard ...!!!
debbieking
Nov 20, 2018 08:15 PM
GO PATS
Dec 11, 2012 08:53 PM
CWH
May 2, 2008 05:35 PM
trev0006
Nov 14, 2007 02:55 PM
Racinfan83
Dec 10, 2005 11:50 PM
