2006 Town and Country power lock issues
Old Oct 20, 2015 | 01:52 PM
bracus's Avatar
Default 2006 Town and Country power lock issues
Since I've bought this recently, the sliding doors power locks no longer work while trying with either the key fob or the switch inside the car. I have to manually unlock those doors. The front two and trunk door will unlock no problem, but not the two sliding doors. Also, the passenger side power lock switch won't work. If you press it, it will give like half attempt. Like there's not enough power. Then if you press it again, it won't even try to unlock the doors. So none of them at all will unlock while trying to use the passenger side. The driver side works for all except the two sliding as I stated though. What's going wrong here? I've also noticed (not sure if it's related) that the odometer will slightly flicker sometimes. It's very faint and only noticeable during night time, but I figured it's power so it's worth mentioning.
Old Nov 5, 2015 | 04:39 AM
msd26129's Avatar
pull the iod fuse leave it out for a minute and put it back in .. this resets everything see if it works then ..
i have this issue but all my doors wont lock i have to pull the fuse reset everything and it works .. sometimes a month other times just a few hours ..
not found a quick fix yet lol
there is an update of the software but only chrysler can do it and they are reluctant here in the uk as they have to use an old computer to do it and there is only 1 in the uk that gets passed around dealers
Old Nov 5, 2015 | 12:33 PM
sounds like door lock motors for the sliding I replace then quite often
Joey-D
Jan 6, 2019 12:34 AM
SPG
Aug 23, 2014 06:53 PM
privat12
Jul 14, 2013 01:05 AM
Mikestravels
9
Feb 22, 2009 04:32 PM
Raybart
Dec 20, 2008 10:47 AM
