2008 T&C auto start problem
When I use my remote starter, the fan on the heater works and the speed is adjustable but there is no air coming out of any of the vents. I have tried switching between floor, dash, combination, defrost, etc. and no air comes out. If I start the vehicle with the key, everything works fine. Any thoughts what my problem is? Thanks
there is a software update for the AC control head visit the dealer for the update
NUMBER: 24-004-08 REV. A GROUP: Heating & Air Conditioning DATE: February 29, 2008 SUBJECT: Flash: Intermittent Mode Door Function - 3 Zone ATC SYMPTOM/CONDITION: Some customers may experience an intermittent condition where the air flow from the HVAC vents do not match their selection on the HVAC control. Pushing the “mode” button on the control head will provide a correct visual indication on the display but the airflow will not match. This may be described as the system is non responsive or locked. They may also indicate that the system works normally the next time the vehicle is started. This may be caused by a low battery voltage condition during a “Remote Start” event. Subsequent vehicle starts (after allowing the bus to go to sleep) will resume normal system operation. DIAGNOSIS: Using a Scan Tool (StarSCAN®) with the appropriate Diagnostic Procedures available in TechCONNECT, verify all ATC systems are functioning as designed. If DTC's are present record them on the repair order and repair as necessary before proceeding further with this bulletin. If the vehicle operator describes the Symptom/Condition and / or it can be verified, perform the Repair Procedure. **PARTS REQUIRED**: Qty. Part No. Description AR (1) 55111807AH Control Head, HVAC NOTE: Replacement only required if flash reprogramming event cannot be completed |
Thanks CTech
Thanks ChryslerTech,
this very thing happened to me yesterday. I notice it is only intermittent. Will the computer store a code? I don't want to have a "could not reproduce" report at the shop. Here's another one: the same day, on a different remote start, the am/fm radio would not work, no presets, no direct tune, nothing. Satellite worked, HDD worked, everything but am/fm. Later on it worked fine; is this related? |
I had my battery checked and it is ok. So does that mean I need to take it to a dealer and have the computer checked?
the dealer has to update the software in the control head
| All times are GMT -5. The time now is 06:46 AM. |
