2008 town and country esp/bas, traction control lights and malfunctions
Old Apr 25, 2018 | 06:46 AM
kathy9's Avatar
Can this be fixed without taking it into a shop? and how if so.
Old Apr 26, 2018 | 09:39 AM
ChryslerCares's Avatar
Hi kathy9,
We recognize that you are looking for feedback from other forum members for possible options. However, if you do choose to visit a dealer, please feel free to let us know so we can provide an additional layer of support.
Julie
Chrysler Social Care Specialist
Old Apr 26, 2018 | 09:57 AM
kathy9's Avatar
I really can't afford to go to a dealer at this time that is why I was trying to see if it can be fixed without a dealer.
Old Apr 27, 2018 | 11:05 AM
vernd's Avatar
Default traction control issues
If you feel like you are capable of tackling this repair on your own, then I would say to go ahead and do the repair yourself. Make sure you disconnect the battery first. I ordered a clock spring from an actual Chrysler/Dodge dealer off of eBay and it was much cheaper. The dealer isn’t necessary for this repair, unless you just don’t feel like you can get it accomplished on your own.
Good luck!
Old May 17, 2018 | 09:15 AM
  #15
Dlobur123's Avatar
Default Steering angle sensor
Just and FYI on the clock spring/angle sensor topic. aftermarket electronic parts are usually iffy, however i used a steering angle sensor from NAPA in my 08 Aspen and have not had any issues. It was 200$ vs the dealers 700
Old Nov 19, 2019 | 09:17 AM
  #16
xupb27kda's Avatar
Default Grinding noise after clock spring replacement
Hi,
We have an 08 dodge caravan. The esp bas light was on. It needed a new steer angle sensor/clock spring. We had the clock spring replaced. That fixed the esp light but now it makes a horrible grinding noise while turning to the left at higher speeds. Any ideas
Old Nov 19, 2019 | 03:57 PM
  #17
the clock spring is inside on the steering column this noise at higher speed would be outside on the wheel the speed of the car would have nothing to do with a noise on a clock spring.
Old Sep 30, 2020 | 09:07 PM
  #18
Celenyhdez's Avatar
Default Question
Originally Posted by vernd
hello, i am new to this forum and i don't really have a question, but i would like to share my problem and my solution with everyone else who may be experiencing similar problems. my wife's 2008 town and country van began acting up about a week ago, and she also had some lights come on, on the instrument panel. when this happened, she also said that she was accellerating from a stop while turning slightly. she said that the van made an awful grinding noise, also. the lights that came on were the ESP/BAS light, along with the traction control light. the van did not have any pcm codes to be extracted. i am a certified mechanic, but i had never experienced any problems similar to this. i knew that this was definaitely a traction control problem and that the grinding was probably the traction control system cutting power to the wheels. after doing some reading, i concluded that the problem with the van was more than likely a faulty "steering angle sensor". the steering angle sensor is located inside of the clock spring, which is in the steering column. the clock spring is also what supplies power to the air bag and allows the steering wheel to turn back and forth, while maintaining a steady power supply to the air bag, horn, and steering wheel radio controls ( if equipped ) after replacing the clock spring/steering angle sensor, the van was back to operating properly. all of the dash lights are off again and no more grinding noise. even though i am a certified mechanic, this job was pretty simple and could be done by a do it yourselfer, without too much difficulty. just be careful and take your time! also, the air bag is not held onto the steering wheel with screws, it has 3 spring type clips, that need to be pryed over. i used a mirror to see them and it made it very easy to see what was going on. i hope this helps somebody that is experiencing the problems that i had with my wife's van. i decided to post this, because i couldn't find much of anything relating to this!
Spoiler
Old Sep 30, 2020 | 09:15 PM
  #19
Celenyhdez's Avatar
Default Question
Hello I have the same problem with my 2008 town&country..I took it to the mechanic He said that replacing the Abs sensor the problem will be solved but I read your post and I think what He said won't solve the problem...just I would like to know what another research you did before to get your last conclusion about the steering angle sensor was the issue .
thanks
Old Oct 1, 2020 | 11:22 AM
  #20
vernd's Avatar
Default steering angle sensor
thanks
It"s been some time since i did this repair on our van, however, your ABS has more to do with a "controlled" stop (meaning a pedal vibration when ABS is activating). The steering angle sensor gave that ABS activation "feeling" (grinding) upon acceleration and a slight turn of the steering wheel. The esp/bas lights were illuminated on the instrument cluster also and if this would have been an abs/wheel speed sensor problem, there wouldn't have been any malfunction lamp for the traction control/esp. I hope you're able to get your problem solved, please post your results. thanks!
