2008 Town & Country TPMS
Old Apr 12, 2015 | 05:31 PM
StratLou's Avatar
Default 2008 Town & Country TPMS
Hey guys,
Another issue if you all don't mind chiming in. The vehicle had 1 tire that was reading lower than all the others by about 4 psi and, as such, the driver info center on the dash showed that value blinking and the low tire pressure symbol on the dash illuminated. Went to the shop and they found a screw in the tire which they plugged from teh outside and buffed and patched from the inside, remounted it and rotated all 4 tires as it was time. Four days later, the tire is reading low again (in the new tire location on the vehicle), the value is blinking, and the low pressure symbol is lit on the dash. I filled the tire with air to match the other tire pressures and the dash values were now all equal...but...the tire I filled was still blinking and the low pressure symbol was still illuminated. Went for a drive around and no change. Any ideas why it's still blinking since the values are all equal? Thanks.
Lou
GPrescott
Jan 7, 2014 10:56 AM
kvanhowe
Jun 14, 2011 07:28 PM
efiguero
Dec 16, 2010 04:40 PM
Paul Scanzillo
Feb 7, 2010 05:50 PM
cms3250
Jan 26, 2010 10:09 PM
