2010 T&C Blower Motor Resistor Location
Old May 11, 2013 | 04:36 PM
jeremydg23's Avatar
Default 2010 T&C Blower Motor Resistor Location
My AC on the 2010 Town and Country only works on high. Can someone tell me where the front blower motor resistor is located and how to access it?
Old May 11, 2013 | 07:50 PM
Ignore #1
Disconnect and isolate the negative battery cable.
2. If equipped, remove the silencer from below the passenger side of the instrument panel.
3. Disconnect the wire harness connector (2) from the blower motor resistor (3).
4. Remove the two screws (4) that secure the blower motor resistor to the front HVAC housing (1).
5. Disengage the retaining tabs (5) that secure the blower motor resistor to the HVAC housing and remove the resistor
Old May 12, 2013 | 12:54 PM
Look for a place where a bunch of wires goes in to the heater-A/C plenum.
Old May 21, 2013 | 06:38 PM
jeremydg23's Avatar
Thanks for the help. I was able to locate it, unfortunately the auto parts store had the wrong resistor so I am awaiting a special order.
I have another question. I reinstalled the failed resistor as a place holder and reconnected the connector. Now the blower only blows warm/hot air. The back still seems to blow cold, but the front is definitely warm to hot air. Resistor replacement shouldn't cause this correct?
Old May 21, 2013 | 09:38 PM
Has nothing to do with the temp of the air only the volume of air.
Old Dec 5, 2015 | 04:19 PM
Bigdaddy's Avatar
Check the tiny 2-wire connector that goes into the HVAC housing, behind the center stack, just to the left of your resistor. As part of the harness, it's very easy to dislodge when you're pulling the connectors from either the front blower motor, or the resistor itself. When unplugged, your a/c compressor will not kick on, and you'll only get warm air.
stiifen.johnson
Apr 13, 2015 12:53 AM
Bobo
Mar 8, 2015 09:24 PM
Bobo
Mar 6, 2015 09:01 PM
josreilly
Mar 23, 2009 02:20 PM
mrotis
Jan 14, 2008 01:27 PM
