2010 T&C Radio Removal and Overhead Compartment Removal
Old Aug 5, 2011 | 03:12 PM
tbird2340's Avatar
Default 2010 T&C Radio Removal and Overhead Compartment Removal
I just got a 2010 T&C and I plan on putting a CarPC in it.. I was wondering if someone can tell me how to get the factory radio out and if there was a trick to removing the entire plastic piece on the top with the storage so I can run some wires..
Thanks much!
Old Aug 7, 2011 | 09:25 PM
tbird2340's Avatar
So no replies?? I found the two plastic pieces you have to pop out to remove the two screws to get the top plastic moulding almost all unscrewed..
With at least those two unscrewed I then have access to two that are holding in the top of the bezel.. I still think there are more as it doesn't pop off with just those but I couldnt' find any others..
Old Aug 9, 2011 | 12:53 AM
Jessech's Avatar
For the stereo removal, look here...
Mopar EASy Scroll to the PDF instruction on the center of the page. Look up your vehicle and it shows how you stereo comes off.
Old Aug 9, 2011 | 07:22 AM
tbird2340's Avatar
Thanks.. Why did you edit out the overhead console?
Old Aug 9, 2011 | 09:57 PM
Jessech's Avatar
I have a 2011 and wasn't sure you meant the overhead console when you wrote "...top with the storage"
The overhead console is removed by pulling down at the corners with firm pressure. Rear then front.
Here are some pict to help you visualize how it's attached...
Image Sheet
MrImapcmd
Dec 4, 2013 09:55 PM
Gotime12345
Aug 24, 2012 05:01 PM
jbauman
Dec 15, 2008 04:17 PM
jbauman
Dec 14, 2008 09:53 PM
choprpilot76
Nov 2, 2007 01:49 PM
