2012 Door Lock Issues
A couple weeks ago when it was freezing cold the lock on my passenger side door stopped working. Trying to lock it with the key fob didn't work and neither did trying to manually lock the door. Door works fine otherwise. Manually opens and closes and also works with the power switches and key fob. Planned on fixing it as the weather warms up.
Today. Much warmer. Open and close the drivers side door. Works fine. Go to open a few minutes later and now the door won't open. Power locks won't work. Manual door lock doesn't work. Try open the door with the key fob and over head switch. Nothing. Is there anything I should be looking at? I tore the door apart and nothing seems to be loose or broken Thanks in advance |
A little confused bc you say manual locking works and doesn't work, and the fob works and doesn't work... Sounds pretty erratic, maybe a bad door module: http://www.moparpartsgiant.com/parts...l-modules.html
Sorry for the confusion The door lock switch on the door (the one you can lock/unlock by hand) does not work on both sides of the van. the drivers side door is locked and can not be opened by pulling on the handles, by using the overhead or by using the key fob the passenger side is unlocked and can not be locked by the front door locks or by the key fob. This door is opening and closing just fine |
