2012 Door Lock Issues
Old Feb 27, 2018 | 07:51 PM
David Brooks's Avatar
Default 2012 Door Lock Issues
A couple weeks ago when it was freezing cold the lock on my passenger side door stopped working. Trying to lock it with the key fob didn't work and neither did trying to manually lock the door. Door works fine otherwise. Manually opens and closes and also works with the power switches and key fob. Planned on fixing it as the weather warms up.
Today. Much warmer. Open and close the drivers side door. Works fine. Go to open a few minutes later and now the door won't open. Power locks won't work. Manual door lock doesn't work. Try open the door with the key fob and over head switch. Nothing.
Is there anything I should be looking at? I tore the door apart and nothing seems to be loose or broken
Thanks in advance
Old Feb 28, 2018 | 12:05 PM
TurboRev's Avatar
A little confused bc you say manual locking works and doesn't work, and the fob works and doesn't work... Sounds pretty erratic, maybe a bad door module: http://www.moparpartsgiant.com/parts...l-modules.html
Old Feb 28, 2018 | 12:41 PM
Sorry for the confusion
The door lock switch on the door (the one you can lock/unlock by hand) does not work on both sides of the van.
the drivers side door is locked and can not be opened by pulling on the handles, by using the overhead or by using the key fob
the passenger side is unlocked and can not be locked by the front door locks or by the key fob. This door is opening and closing just fine
liksmuzic
Jun 13, 2014 04:52 PM
dakrt360a
Oct 4, 2013 11:32 AM
Cglaspie
Sep 28, 2012 04:24 AM
pawtucket_chrysler
May 20, 2012 04:26 PM
dammarler
Aug 14, 2007 09:52 AM
