2012 Town and Country Noise behind driver rear wheel
Good evening,
We've had this van for about a month, and noticed something this evening that I am unable to identify. When I turn the van off there is a running sound behind the driver side rear wheel. Sounds similar to a fan running. I've tried googling for an answer, closest I could find is it could be the fuel evaporation leakage checking system or ELDS. It's been running for over an hour, is that normal? Or is the noise from something else? Has anyone else ran into this?
Thanks in advance for any help you all can give.
There have been issues with the fuel pump relay, mostly causing stalling and no-start problems, but there have been cases of the fuel pump running after the vehicle is turned off.
The bad news is the relay is soldered onto a circuit board inside the TIPM (Totally Integrated Power Module), for more information see this site: TIPM Repair & Bypass Solutions for 2007-2014 Dodge/Chrysler/Jeep/VW Vehicles
Recently had this issue on my 2012 van and it is related to the fuel pump regulator (not sure if that is the term) and wiring that has shotted out. Not a cheap repair but repairable.
bigragu21@sbcglobal.net
Apr 14, 2016 11:32 AM
justfun251
Jan 22, 2016 10:11 AM
jhuf
Feb 3, 2013 11:56 AM
brilyn
Aug 12, 2011 03:27 AM
