2012 voyager intermittent rad. Fan startup while vehicle turned off
Hi everybody.
Im having a weird problem with my Lancia voyager 2012. Its equipped with a start/stop button. Now some time after parking it started to intermittently start the rad. Fan for a second or two and turn off again, around 3 such cycles per 10 seconds. After few minutes it might stop for a while and then start again. Now when i tried to turn on the ignition it seems like a short circuit is happening somewhere. Lights blink and i get different error codes and a flat battery sign. We only got the car last week. Previous owner hasn't had the intermittent fan startup but has had issues with start/stop button before. Surely im not the only Lancia owner facing such problem. Google hasn't been too helpful either.
best regards,
Ray
best regards,
Ray
So turns out this has happened before about a year ago to the previous owner. Issue was tracked to corroded 3 relays/wires underneath the battery. The issues with start/stop button is most likely a flat battery after few hours of fan startup. I'll inspect and if its anything other than these corroded wires i'll let you guys know.
