2012 voyager intermittent rad. Fan startup while vehicle turned off
Old Jan 7, 2021 | 01:46 PM
Rahe01's Avatar
Default 2012 voyager intermittent rad. Fan startup while vehicle turned off
Hi everybody.
Im having a weird problem with my Lancia voyager 2012. Its equipped with a start/stop button. Now some time after parking it started to intermittently start the rad. Fan for a second or two and turn off again, around 3 such cycles per 10 seconds. After few minutes it might stop for a while and then start again. Now when i tried to turn on the ignition it seems like a short circuit is happening somewhere. Lights blink and i get different error codes and a flat battery sign. We only got the car last week. Previous owner hasn't had the intermittent fan startup but has had issues with start/stop button before. Surely im not the only Lancia owner facing such problem. Google hasn't been too helpful either.
best regards,
Ray
Old Jan 7, 2021 | 11:47 PM
Rahe01's Avatar
So turns out this has happened before about a year ago to the previous owner. Issue was tracked to corroded 3 relays/wires underneath the battery. The issues with start/stop button is most likely a flat battery after few hours of fan startup. I'll inspect and if its anything other than these corroded wires i'll let you guys know.
tcx3
Nov 7, 2010 06:33 AM
moneli_p
Jan 22, 2010 12:19 PM
E74776
Nov 24, 2007 02:13 PM
dandiesel
Feb 2, 2007 08:24 PM
db75240
Feb 12, 2006 11:50 PM
