2013 T&C Power liftgate problem
Old Jan 17, 2016 | 09:51 AM
Buckeye492's Avatar
Default 2013 T&C Power liftgate problem
I have a 2013 T&C that when the rear liftgate is opened using the FOB, it goes about 3/4 of the way open then starts to "ratchet" up and down until it finally opens the entire way. When you try to close it, it starts to close & gets about 1/4 of the way down then starts the "ratcheting" again & ultimately opens back up. I am not sure if there is a way to re-calibrate or re-learn the liftgate opener. Any help is greatly appreciated.
Old Jan 20, 2016 | 12:43 PM
ChryslerCares's Avatar
Hi Buckeye492,
It's possible that one of the connectors may need to be cleaned and secured. I would recommend having your local servicing dealership take a look at the liftgate to assist in obtaining an accurate diagnosis.
Old Mar 3, 2023 | 02:21 PM
emilydoty's Avatar
Default Same issue
Did you ever figure out what was wrong? I’m having the same issue with mine. The wires were replaced today but that didn’t fix anything.
Old Mar 11, 2023 | 04:56 PM
woodthumb's Avatar
my 06 did close to same thing few years back and i changed out the struts... good as new for me ...??? cheap try
Kartopics
Sep 7, 2019 05:07 PM
73Mike
May 24, 2016 09:43 PM
lanilani
May 5, 2011 02:48 PM
boise_chief
Feb 28, 2011 08:16 PM
nitlionlover
Aug 18, 2010 09:50 AM
