2013 Town and Country stalling
Old Feb 16, 2026 | 06:58 PM
BADPIG's Avatar
Default 2013 Town and Country stalling
Hey...so I have a 2013 TC Touring 196,000mi...VERY frustrating problem. After filling up with gas...at varied times/distances from gas station, the vehicle just stalls and shuts down. Lights, radio, wipers all still work. NOW...after 30min +- the vehicle starts back up and is fine...until the next fill up! It does NOT CAUSE A CEL!
I have REPLACED:
TIPM
Fuel Pump
Map Sensor
Purge Solenoid
Also tried the fuel pump relay bypass in the TIPM. Again..NO check engine light!!
Any ideas?? About to give up on it!
Old Feb 17, 2026 | 08:01 AM
ggoose's Avatar
Question - When you fill the gas tank, do you top-off, that is try to squeeze 'just a bit more' gas into the tank, or stop when the handle clicks off? Topping off can force liquid gas into the evap purge canister which then gets sucked into the intake as a slug of liquid rather than gas vapors when starting back up. This slug of liquid gas causes the stall.
Old Feb 17, 2026 | 08:09 AM
BADPIG's Avatar
Man...I have tried every way of fueling..slow...nozzle in...nozzle out...only filling to 3/4...My mechanic was a Dealer tech before going solo. He is as perplexed as I am..the no check engine light is baffling
Old Feb 17, 2026 | 08:13 PM
sounds like a purge vapor system issue fill up with gas unplug your purge vapor sednoid electrical connector and see if you stall after that's unplugged and not pulling vapor and possibly liquid fuel into the system and choking the engine.
Old Feb 17, 2026 | 08:56 PM
BADPIG's Avatar
I replaced the Purge Solenoid...but I will try unplugging it after refueling....the Van can run with it unplugged? Thanks for the input!
Old Feb 20, 2026 | 06:35 PM
BADPIG's Avatar
quit again today...unplugging purge solenoid made no difference...with the exception it threw a CEL for Evap..purge solenoid...on to the next
"REMEDY"....thanks for tge suggestion!
Old Feb 20, 2026 | 08:42 PM
next thing is to have a scanner on it and see what goes missing when it stalls. A high end professional scanner can record life data and save it to look at the data later
Old Feb 21, 2026 | 01:03 AM
BADPIG's Avatar
so some type of scan tool that records data while in operation? I'll look into that...but I am fast approaching the sell as-is stage!! Not sure I'll spend $$ if the tool costs! Thank You for responding...I'll update
Old Feb 21, 2026 | 03:35 PM
it will likely be a 400 plus style scanner
Old Mar 23, 2026 | 05:29 PM
mougly's Avatar
Peehaps your evap canister is clogged.
https://m.youtube.com/watch?v=Bez-8iOUPPk#
