3.8 AWD overheating
Old Sep 1, 2007 | 05:54 AM
ian121's Avatar
Default 3.8 AWD overheating
Hi
I have browsed the net and found many posts on this area. My 1998 AWD started having overheating problems in that the water would shoot out of the expansion tank! This was seldom though and I could not trace why. The other day when I stopped and turned the engine off, the fans kept running and the only way I could switch them off was by disconnecting the battery. To my dismay, when I connected the battery again hours later, the fans came on!? Fortunately they went off again after a while.
This time though when I started the car and let it run, the fans did not come on to cool the radiator. I also have no AC coolant so I could not test the fans using the AC. I did track from reading many posts over the web, that this pointed to the fan relay. I removed the old one (4707286AD Rev C) and purchased a new updated one (4707286AF Rev A). Unfortunately this did not fix the problem! Any suggestions?
I read that it could be an airlock, how do I make sure there is no air in the system? (The Voyager is the European equivalent of the Town and Country model).
I also read that it could be the temperature sensor and that this can be tested by reading resistance measurements at hot and cold. How do I do that?
I also understand it could be the fans. I read that you can shortcut the green/black cable to the black cable of the socket that goes into the fan relay. This did not bring the fans on. I did turn on the engine but the fans remained off. I presume this should turn the fans on immediately? I would really appreciate some advice on how to test the fans.
Any ideas of what I should do next would be greatly appreciated.
Thanks for any help
Ian
Old Sep 2, 2007 | 01:46 PM
ian121's Avatar
Default RE: 3.8 AWD overheating
Any ideas anyone?
twoloosescrooze
Dec 8, 2006 07:35 PM
wonderboy
Aug 14, 2006 01:41 PM
Morparth
Jun 19, 2006 10:04 PM
Feb 21, 2006 09:56 AM
Dutchessyville
Feb 5, 2006 11:30 PM
