About shifting carbon deposits.
Old Jul 9, 2015 | 03:58 PM
Leedsman's Avatar
Default About shifting carbon deposits.
Many times I've said on here there is no known substance that will dissolve carbon. This is still true.
However, the boffins have come up with a system that will clean up the entire fuel system of a petrol car (at least) without dismantling, INC. the CARBON.
It involves disconnecting the normal fuel system, substituting another one using "special" fuel which contains -ve ions that attach to +ve carbon ions in the whole system, including injectors.
It also involves running the engine in this state for an hour at idle plus 50%.
Specialist engineers can do this for you, and it is claimed involves spending £70 or so.
It seems to make a dramatic reduction in unburned hydrocarbons as indicated on the exhaust gas analyser, reducing a 'fail MOT' situation to one tenth or so, therefore a 'pass'.
I simply pass on to you this information, I know nothing else about it, the idea is very new.
Leedsman.
Old Jul 9, 2015 | 07:17 PM
Irish - I first saw it on the XK8 episode of WD with Ed China about 2012[ish] Unless you failed a UK emissions test or have bad blue smoke I see no point although any high mileage might well benefit in terms of MPG.
Dealer instruction video here at
dna9656
Oct 11, 2014 03:06 PM
mortikai
Apr 9, 2014 12:07 AM
MADDOG
May 18, 2007 12:33 AM
Oct 14, 2006 06:12 AM
LGT Automotive.com
Oct 28, 2005 12:23 PM
